snip Posté(e) le 17 février 2013 Signaler Posté(e) le 17 février 2013 http://www.flarm.com/support/updates/HISTORY.txt5.08 2013/02/15----------------This update is strongly recommended for all IGC devicesOnly updated devices will remain IGC approved!ADD: New Encryption Algorithms, old FW versions will no longer be supported AND IGC APPROVED ! Disponible ici : http://www.flarm.com/support/updates/index_en.html Citer
Administrateur Posté(e) le 17 février 2013 Signaler Posté(e) le 17 février 2013 A significant update to the GPS Flight Recorder function of FLARM-IGCunits is now available. Owners are advised to incorporate this as soonas possible. It is available through a web download, see below. FLARM-IGC owners may recall that in 2012, software appeared on the webfrom an unknown source that enabled false Flarm-IGC files to be producedthat passed the IGC electronic validation check. To counter this, asecurity update to Firmware Version 5.8 is now available via: www.flarm.com/support/updates/index_en.html and click on "flarm_508fw" on the right hand side of the page todownload this file. This file will update a FLARM-IGC unit to Firmware5.08 standard using the standard FLARM update procedure (via a micro-SDcard or a PC-based update). Note that an update to the Flarmtoolutilities program incorporating V5.08 is also available by clicking"Installation V5.08" on the right hand side of the same web page. ** Important Note ** Owners should note that the IGC-approval forearlier versions of Firmware (from V4.0 to V5.6) will be withdrawn on 30April 2013. This is to ensure that the possibility of false IGC filesbeing produced using the malicious software referred to above, iseliminated. A revised IGC-approval document is available on the IGC and GFAC web pages: www.ukiws.demon.co.uk/GFAC/approvals/flarm-igc.pdf or www.fai.org/gnss-recording-devices/igc-approved-flight-recorders For electronic validation of IGC files produced with V5.8 firmware, useeither the latest Flarmtool program (see above) or the free IGC Shellprogram together with the latest Flarm DLL file which is namedIGC-FLA2.DLL to differentiate it from the earlier file IGC-FLA.DLL. For the IGC Shell program and DLL files, including the new IGC-FLA2.DLL, see: www.ukiws.demon.co.uk/GFAC/downloads.htm or www.fai.org/gnss-recording-devices/free-software Citer Une même passion, 3 sites : http://www.planeur.net - http://www.volavoile.net - http://www.NetCoupe.net
berthet jp Posté(e) le 18 février 2013 Signaler Posté(e) le 18 février 2013 (modifié) y'a comme 1 problème : quand on clique sur la version 5.08 -qui n'apparaît que dans la version en anglais- on retombe sur la version 5.06... du moins pour le chargement par carte SD Modifié le 18 février 2013 par berthet jp Citer
snip Posté(e) le 18 février 2013 Auteur Signaler Posté(e) le 18 février 2013 y'a comme 1 problème : quand on clique sur la version 5.08 -qui n'apparaît que dans la version en anglais- on retombe sur la version 5.06... du moins pour le chargement par carte SD Depuis la page http://www.flarm.com/support/updates/SD_Nutzung_index_en.html j'ai bien un lien vers http://www.flarm.com/support/updates/flarm_508.fw qui semble être la bonne version. Pas toi ? Citer
Tatave Posté(e) le 18 février 2013 Signaler Posté(e) le 18 février 2013 Si j'ai bien compris, cette MAJ n'influe que sur l'habilitation du FLARM comme logger IGC, mais n'a pas d'influence sur la fonction principale, à savoir l'anti-collision. Les FLARM non mis à jour continueront à détecter les autres et à être détectés par eux. Est-ce que je me trompe ? Citer
LsFab Posté(e) le 19 février 2013 Signaler Posté(e) le 19 février 2013 Si j'ai bien compris, cette MAJ n'influe que sur l'habilitation du FLARM comme logger IGC, mais n'a pas d'influence sur la fonction principale, à savoir l'anti-collision. Les FLARM non mis à jour continueront à détecter les autres et à être détectés par eux. Est-ce que je me trompe ?En théorie oui, mais FLARM indique à chaque grosse MAJ que les versions antérieures ne sont plus supportées, donc il vaut mieux mettre à jour, même si normalement la détection reste présente avec les anciennes versions, même si elle est moins performante Citer
berthet jp Posté(e) le 19 février 2013 Signaler Posté(e) le 19 février 2013 je confirme : quand je clique sur http://www.flarm.com...s/index_en.html j'arrive sur la page Updates où on trouve à droite sous la photo de KO : DownloadFirmware v5.08 (Feb 2013)For all devicesBy serial cable:Flarmtool v2.0 with Firmware v5.08Installation v5.08 (22 MB)5.xx revision historyBy SD card:All devices:flarm_508.fw (1.8 MB) et quand on clique sur flarm_508.fw, (by SD card) on est renvoyé sur une nouvelle page End user license agreement avec : DownloadFirmware v5.06 (Jul 2012)by SD card:flarm_506.fw (1.8 MB Citer
LsFab Posté(e) le 19 février 2013 Signaler Posté(e) le 19 février 2013 Ca vient peut-être d'être modifié mais j'ai bien la 5.08 sur ton lien : http://www.flarm.com/support/updates/flarm_508.fw Citer
