Pour la question du vario :
7.2 Audio Variometer
In addition to the variometer display XCSoar provides an acoustic variometer which transfers the variometer measurements are transferre into sounds. The audio variometer is for now only available on android devices. For proper performance connect your device to a barometric sensor or use the internal one of your android device if provided. The audio vario is enabled/disabled via the gauges configuration in the configuration
page 100 du manuel : http://download.xcsoar.org/releases/6.7.5/XCSoar-manual-fr.pdf
Mais je n'ai pas essayé...
Amitiés
  • Réponses 51
Je confirme : fonctionnement correct du vario audio, peut-être un léger retard, de XCSoar sur Quechua Phone.
Amitiés
