Invité Olivier Dancer Posté(e) le 15 juin 2003 Signaler Posté(e) le 15 juin 2003 4.25: New feature: Implemented Team page. Bug fixes: fixed random hang in Flight Plan page. Team page (see below): To enable it, go to Menu.Edit, and select Team into one of the Menu buttons.This page allows tracking up to three other gliders. Positions of these gliders can be entered in Grid coordinates, that are communicated via radio between gliders, or between ground station and gliders. Grid coordinates are dependent on the center of the grid setable on the Team page. When the Team feature is enabled, in the lower left corner of the map WinPilot displays the current grid coordinates, which can be communicated to other gliders, or to ground station running WinPilot XP. To track other gliders, first enter their competition sign (this can be done in the Simulator mode on the ground). Then, to enter a position of that glider, press the button next to the competition sign of that glider.The map will pan to show that glider (click Restore to center the map back on your glider). http://www.winpilot.com/images2/Menu_Team.gifTeam page 4.24 - Implemented new Menu button : '1 Term' to display or hide the predicted by WinPilot position of thermals. This button is only active when a Thermal Database is selected into Menu.Files, and is by default assigned to the fourth iPAQ front button (this can be reassigned via Menu.Edit).Final glide information is now present on the Details page even for non-landable user waypoints.Added Un-Goto to McCready page when the user has invoked the GoTo function. Bug fixes: implementing preserving state of Terrain on/off when program is exited, improper screen refresh when Touch/SUA Info was selected.
