Gilles Navas Posté(e) le 26 novembre 2004 Signaler Posté(e) le 26 novembre 2004 Pour information, puisque ayant appris cette nouvelle par accident voici quelque mois. Destiné à ceux qui pensent tout savoir sur le comportement aux grands angles. Peter était compétiteur lors des WGC 1995 en Nouvelle Zélande dans notre classe (15 mètres FAI) dans laquelle concourait, Gérard Lherm, Eric Napoléon et moi même.Nota : Il est inutile de polémiquer stérilement. This in from Tom Knauff.It doesn't appear that Peter did anything silly, so there might be a lesson in this for all of us. Rick ------------I've had lots of emails asking for any information about Peter Masak's accident. Doris and I flew our Scheibe SF28A motorglider, retracing Peter's flight. There is nothing remarkable about the events leading up to the accident. He was obviously planning to fly to, and over Tussey ridge, into ridge lift and then south to a turnpoint. If he were successful, he would have been the only pilot to do so, and probably would have easily won the day. Only two other pilots flew to a nearby turnpoint, (Spruce Creek) and then returned towards the contest site. We began retracing the flight by flying the course and altitude as he crossed the Huntingdon valley, west bound towards Tussey Ridge. Tussey is about 1,900 MSL feet high in the direction he was heading and from a few miles away, it would have been easily seen he would need to find some lift in order to clear the top of the mountain. Approaching Tussey from about 3 miles away, it would be obvious he would need to try ridge soaring another ridge in order to gain altitude. It is hard to explain, but Tussey Mountain doubles back on itself, then doubles back again as it continues South. Peter flew around the end of the 2,200 ft high mountain, and maintained 1,833 feet for several seconds before the short ridge makes a slight bend so the moderately strong SW winds were more favorable. The glider gained altitude to nearly 1,900 feet MSL, and he was only 2,500 feet downwind from the 1,900 ft high Tussey Ridge. There is a very good landing field at the base of the ridge, and I am sure he was not concerned at all about being able to abort the attempt and land in this or any of several other fields nearby. As Doris and I retraced his flight, I could not help believe I would have done the same thing in the same circumstances. The valley he was in was wide enough that a rather shallow turn could have been made, and I am also sure Peter's confidence was buoyed by his slight gain of altitude. He could not fly further into the "V" shaped valley, as the terrain was rising in front of him. He would have tried to fly a sharp 180 degree turn to return to the lifting air he had just passed. The flight track shows the glider losing 350 feet of altitude in a very small space, which can only be caused by a spin. It is a very heavily wooded area, and the glider hit a large tree. Peter first began flying at our gliderport in 1979, and he was an accomplished pilot. Why the glider spun probably won't be answered. Although the glider was called the Scimitar, it really was a Ventus after Peter replaced his own designed wings with Ventus wings a couple years ago. Many factors we might not consider at first could have contributed to the accident. Weight and balance must be considered. Many pilots move the CG well aft in an attempt for better climb performance. Peter might have lost weight, which can also affect CG. Peter was instrumental in designing winglets for gliders, and even tried a sound-generated boundry layer device. I am unaware of any other modifications he might have made on his glider. When Doris and I were circling in the valley, a thermal gently lifted us upward, and a Red Tailed Hawk joined our thermal. This bird probably has a nest nearby. Could the same hawk have distracted Peter? Did he try to avoid it? I doubt if we can know what actually happened, but I expect this accident will cause many of us to re-evaluate the risk level we are comfortable with. Thomas KnauffKnauff & Grove Soaring Supplies3523 South Eagle Valley RdJulian, Pa 16844Phone (814) 355 2483Fax (814) 355 2633 www.eglider.org Citer 1L
Invité bruno Pieraerts Posté(e) le 30 novembre 2004 Signaler Posté(e) le 30 novembre 2004 bien triste nouvelle!!! Citer
