Administrateur Posté(e) le 20 avril 2005 Signaler Posté(e) le 20 avril 2005 3 Mises a jour pour les produits SeeYou le 20/04/2005 : SeeYou3.1 : http://www.seeyou.wsMajor Upgrades: (reverse order of implementation)Version 3.1+ 100m resolution maps in 2D view+ FAI Optimizations for Goal, Out and Return, FAI Triangle and Free 3 turnpoint tasks+ Support for Garmin USB devices+ Support for Cambridge 302 devices+ Wind is calculated in straight flight if TAS/IAS and GS are stored in IGC file Minor Upgrades: (reverse order of implementation)Version 3.1- Pan/Zoom/Measure modes in 2D view. F2 switches between the modes- Average indicated airspeed shown in statistics- Windsock in 3D view- Raster maps can be grouped for faster switching on and off- Corrected problem with loading HGT data in 3D which caused the progress bar to stop in the middle- Terrain quality added to 3D options dialog- Progress bar shows downloading of HGT files- Sun angle for shading can be setup in Options > Vector Maps- Support for new IGC rule for reduced leg distance when using 500m cylinders- Histograms in statistics have a legend- Plane turns into the heading direction (crabbs with cross-winds)- New items added to Flight properties: Wind, AGL, IAS, TAS, Trk, GPS Alt. Nett, Wind component- Wind units added to Options > General- It is possible to open several flights from Day results in SeeYou Competition- New parameter CompID for the competition scripts- Printout of all competitor's details- Minimum and Maximum length of Speed/Distance task adopts new IGC rules- Custom synchronization of flights in Animate > Synchronization- Revised engine detection algorythm- New legend for Multiple flights, GPS Status and Airspace check color schemes- Ticks at a given time-separation can be setup in Options > Flight- Miscellaneous bug fixes SeeYou Mobile 2.3 : http://mobile.seeyou.wsVersion 2.3 brings: . Declaration upload for all supported devices!. Support for the Bräuniger Compeo NMEA sentences ConnectMe 1.2 : http://connectme.seeyou.ws/ Citer Une même passion, 3 sites : http://www.planeur.net - http://www.volavoile.net - http://www.NetCoupe.net
Pierre Posté(e) le 15 mai 2005 Signaler Posté(e) le 15 mai 2005 (modifié) Quelqu'un pourrait-il me dire s'il a déjà essayé Connect me et ce qu'il en pense ?Quel cable utiliser entre un iPAQ et un LX5000? Modifié le 15 mai 2005 par Pierre Citer Gliders pilots do it better
Fred Posté(e) le 15 mai 2005 Signaler Posté(e) le 15 mai 2005 Quelqu'un pourrait-il me dire s'il a déjà essayé Connect me et ce qu'il en pense ?Excellent ! Quel cable utiliser entre un iPAQ et un LX5000?J'utilise le meme cable que pour connecter mon logger a mon IPAQ ..... trouve toi un cable "NMEA" entre un LX5000 et ton PDA ! A+ Citer Faites que le rêve dévore votre vie afin que la vie ne dévore pas votre rêve
