Invité Olivier BO Posté(e) le 11 septembre 2003 Signaler Posté(e) le 11 septembre 2003 Bonjour à tous Je recherche une adresse mail ou un site sur le net concernant les moteurs TOP que l'on rajoute sur presque tout les planeurs monos. Merci Citer
Fred Posté(e) le 11 septembre 2003 Signaler Posté(e) le 11 septembre 2003 Salut, Il y a effectivement des top sur des ASW24, Ls6, Ls7, ASW20, Ventus, Discus ....... pour en avoir vu en oeuvre : faut pas mal de piste ! Tu auras plein d'infos en regardant sous : http://groups.google.fr/groups?hl=fr&lr=&i...viation.soaring TOP Self Launch engineThis is not a translation of the online German document but based onmy experience and knowledge as an owner and operator for over 10years. I have also met and talked with the designer. BackgroundThe Fischer TOP was designed and manufactured by Thomas Fischer inGermany in the 1980's.The first unit was fitted to a Kestrel 17 after a shape representingthe TOP had been fitted so that performance testing could be done to determinethe effect on glide performance. It was determined that the TOP caused 2 kilograms of drag at 100KIAS. Given that a 400 Kg glider has a glideangle at 100 knots of about 25 or 16 Kg of drag the effect on performance caneasily be determined. TechnicalThe unit has a 24 HP Konig 3 cylinder radial engine which developsmaximum power at 4200 rpm with toothed belt reduction giving propellor rpm ofabout 2400. The fuel tanks are part of the unit and hold 8.5 liters of fuel,good for about 45 minutes at full power. Pilot reports are that an LS4fitted with TOP will climb from sea level to 14000 feet on a full tank. There is a 3 bladed carbon and kevlar folding propellor whichautomatically folds when the engine is stopped. This makes the TOP one of theeasiest to operate motor glider power units as the prop does not have to stoppedin a particular position.There is also a safety benefit in that if the engine fails the propwill stop and fold reducing the drag dramatically and giving a glide angle ofabout 25 at around 50 knots. This makes the emergency landing much easier. Extension and retraction is electric and electric start is fitted.Several timers are built in to the control unit for ignition delay of about 3seconds after cranking starts to give the prop time to partially open and a 12to 15 second delay for retraction to give the engine time to cool. Theaircooled engine is very smooth with little vibration and not too much noise andit warms up and cools rapidly. Engine starts can be done with only 50feet altitude loss. No generator is fitted.Batteries for the TOP are fitted in the nose of the glider whichgenerally means little ballast is required to bring the Center of gravity of aTOP fitted glider to the right place. Structural modifications are minimal. A couple of small bulkheads inthe turtledeck with M10 bolts built in. A hatch is required for the quickdisconnects for the throttle, choke and fuel shutoff and the multipoleelectrical connector. Fitting and removing the unit takes a matter ofminutes and no adjustments are required. A starter solenoid, controlpanel and engine instrument(tacho and CHT) and associated wiring are allthat remains in the glider when the unit is removed at small weightpenalty.(a few pounds) In Germany the TOP was certified on ASW 20 and 20B, StdCirrus and Astir single seater. In Australia the units have beenfitted to several LS3 and LS4, a Ventus A, a Ventus C, a Discus A a LS3-17as well as ASW20B and ASW20. While you would not want to compete in an unhandicapped contest withthe TOP(you can't really carry water ballast anyway) the glider retainsits handling qualities and suffers only a small performance penalty incross country speed against the same glider without TOP - around 4 to 5%. Itturns many older and not so old gliders into self launchers which can beused for fun and contest practice. The TOP can easily be removed for seriouscontest work with essentially zero penalty apart from a few pounds emptyweight increase. Land out on an airfield and your crew can forget the trailerand bring the TOP out in the back of the car! The unit weighs about 46 kilograms with batteries and fuel. Thisweight actually has the same effect as water ballast so the performancepenalty against the same glider without TOP is less than you might think athigher speeds. In low speed flight the extra weight seems to be the onlynoticeable difference and the turtle deck area near the trailing edge of the wingis a bad area anyway so filling it with the TOP doesn't seem to havebad effects at low speeds. If you want to fit a TOP to other gliders than the types mentionedthere are several things to look for. You want a maximum weight of around 400 to430 kg including the TOP and pilot, You need a turtle deck area that can havethe structural reinforcement fitted and the maximum weight of non liftingparts should accomodate the proposed pilot plus TOP. This latter can be aproblem but it is sometimes possible to reduce placarded speeds. The old OpenCirrus appears to be a suitable glider. The Speed Astir is another.Some gliders were made in turbo and self launch versions withstronger spars like the Discus and Ventus 1. Once the turbos or factory self launchversions were in production all the subsequent gliders got the stronger sparsso that production mix ups could not occur.My Ventus C ("a" fuselage) is one of these as was a friend's DiscusA. These gliders carry the TOP without any structural implications for thewing.Check with the manufacturer. Some are more helpful than others.Klaus Holighaus was very helpful with my Ventus installation byproviding a written statement that my glider had the CM motorgliderwings and also provided the turtledeck layup details so we couldcalculate the attachment strength we had. He also provided CM manualsand a staeement that we could use those speeds and weights. Around 100 TOP units were made up to end of production in the early90's.The unit is currently not in production but I believe the project isfor sale.It is possible to buy the occasional used unit(sometimes with theautobahn induced glider wreck) at quite attractive prices. Limitations A TOP fitted glider ain't a rocket ship! It will climb at around 300feet/min and take off in less than 500 meters run to 50 feet at sea levelstandard day conditions on a sealed runway. Rough soft surfaces and/or long grassare a no no. Live at 5000 feet or more above sea level and you had betterhave a long runway. My wife says that the Ventus C at 2100 feet above sea level lifts offand climbs out at similar angles to the local Piper Tomahawks and Cessnasalthough the speed is about 50 knots instead of 70 to 80 knots. In the event of a low altitude engine failure the prop folds and stopsand you have about Blanik performance. Ths is much better than the13:1 to 17:1 glide angle of some of the other self launchers and even thoughthey would be higher in the same place the options are no better. There is obviously a glide performace penalty but you still have a high performance sailplane and if you dial in 10 % bugs and about 15%extra weight over normal empty glider your final glide will work out. ConclusionThis device needs to go back into production! A mark 2 version with alittle more power(say 28 -32HP) would be welcome.The current engine is in production in Canada for powered parachutes. A version of the ASW24 was made with a TOP sunk into the turtle deckwith only the upper cylinder fairing and prop showing when retracted. Thiscaused loss of only about 1.5 points of glide versus about 3 to 4 points withthe completely external version. The Mistral sailplane also was available with the "Kiwi" TOP versionsimilar to the ASW24 TOP.Similar arrangements could be engineered to use other engines. Certification would be a problem and was one of the reasons for theproject's demise.Countries with sensible regulations for sporting gliders, USA(andcountries with similar Experimental regs, like South Africa) shouldbe good markets. Anyone with further questions please email me and I'll put all thereplies togther in an amended version of this document in about aweek. Mike Borgelt 28 June 2003 Citer Faites que le rêve dévore votre vie afin que la vie ne dévore pas votre rêve
