Airworthiness Directive Dg
Invité Invité_Virely.o_*
Pour plus d'info voir le lien
AD NUMBER: 2005-26-11
MANUFACTURER: DG Flugzeugbau GMBH
SUBJECT: Airworthiness Directive 2005-26-11
SUMMARY: The FAA adopts a new airworthiness directive (AD) for certain DG Flugzeugbau GmbH ModelsDG-800B and DG-500MB sailplanes. This AD requires you to modify the connection of the starterring gear to the lower drive belt pulley adapter. This AD results from mandatory continuingairworthiness information (MCAI) issued by the airworthiness authority for Germany. We areissuing this AD to prevent the bolts currently used to connect the starter ring gear to the drive beltpulley adapter from shearing off and the bolt heads falling into the engine compartment. Failure ofthis connection could render the engine inoperative. Consequently, this failure could lead to lossof control of the sailplane.
For complete details, please see Avantext's website at http://www.avantext.com/DailyADIndex.ASP?AD=20052611
