Junior Posté(e) le 11 avril 2008 Signaler Posté(e) le 11 avril 2008 Bonjour Mon père a volé hier sur le duo avec un flarm équipé de la dernière version, il a croisé un de nos LS6 équipé aussi de la dernière version il y a bien eu détection par contre il a croisé l'asw20 qui n'a pas mis la version à jour et aussi le LS1 de Vincent avec la red box et aucune détection de faite. C'est normal l'incompatibilité entre version de flarm et entre flarm et red box? Vincent P Citer
Régis Posté(e) le 11 avril 2008 Signaler Posté(e) le 11 avril 2008 (modifié) Trouvé sur le site de FLARM : *********************************************How does the 2008 update process work?Users may update their devices at any time once the update is available. Devices with v3.xx firmware will remain fully functional up to April 1, 2008. Updated devices will remain fully compatible with v3.xx firmware devices until April 1, 2008. This means that updates must be done anytime during March 2008. The following restrictions apply for devices with v3.xx firmware: After the end of February, the device will power up with a recoverable error, indicated by blinking lights and error code 0x11. The user may simply wait 30 seconds (or, depending on model, click the button, see your manual) and the device will work as always. On April 1, 2008 the devices with v3.xx (i.e. no update done) will refuse to start-up as compatibility is not given. This is indicated by permanently displaying the error code 0x11 (see manual for details). Also on April 1, 2008 the new features and algorithms automatically get activated. Beta versions of the firmware as it will run after April 1, 2008 are available to interested parties on a restrictive level and will not interfere or interoperate with the rest of the FLARM network. What if I do not update by April 1, 2008?Your FLARM will start up with a permanent error code. You need to do a firmware update prior to using it. There will be no alerts and others will not receive your signal!********************************************* 1) Tous les Flarm auraient du être mis à jour (V 4.xx) avant le 1er avril2) Il semble que les versions 3.xx fonctionnent quand même alors qu'elles devraient montrer un message d'erreur3) Il semble donc que actuellement des Flarm V 3.xx volent en même temps que des Flarm V 4.xx et ne se voient pas les uns les autres. Modifié le 11 avril 2008 par Régis Citer
Junior Posté(e) le 11 avril 2008 Auteur Signaler Posté(e) le 11 avril 2008 Trouvé sur le site de FLARM : *********************************************How does the 2008 update process work?Users may update their devices at any time once the update is available. Devices with v3.xx firmware will remain fully functional up to April 1, 2008. Updated devices will remain fully compatible with v3.xx firmware devices until April 1, 2008. This means that updates must be done anytime during March 2008. The following restrictions apply for devices with v3.xx firmware: After the end of February, the device will power up with a recoverable error, indicated by blinking lights and error code 0x11. The user may simply wait 30 seconds (or, depending on model, click the button, see your manual) and the device will work as always. On April 1, 2008 the devices with v3.xx (i.e. no update done) will refuse to start-up as compatibility is not given. This is indicated by permanently displaying the error code 0x11 (see manual for details). Also on April 1, 2008 the new features and algorithms automatically get activated. Beta versions of the firmware as it will run after April 1, 2008 are available to interested parties on a restrictive level and will not interfere or interoperate with the rest of the FLARM network. What if I do not update by April 1, 2008?Your FLARM will start up with a permanent error code. You need to do a firmware update prior to using it. There will be no alerts and others will not receive your signal!********************************************* 1) Tous les Flarm auraient du être mis à jour (V 4.xx) avant le 1er avril2) Il semble que les versions 3.xx fonctionnent quand même alors qu'elles devraient montrer un message d'erreur3) Il semble donc que actuellement des Flarm V 3.xx volent en même temps que des Flarm V 4.xx et ne se voient pas les uns les autres. Ok merci Regis Je vais finir de les mettre a jour ce WE Vincent P Citer
mik-mik Posté(e) le 11 avril 2008 Signaler Posté(e) le 11 avril 2008 Eh oui ! Il y a une erreur sur la page planeur.net que voilà qui parle du 1er mai.Je comprends maintenant pourquoi ça ne marchait pas. Citer Droit devant soi, on ne peut pas aller bien loin.Saint-Exupery
Administrateur Posté(e) le 11 avril 2008 Signaler Posté(e) le 11 avril 2008 Eh oui ! Il y a une erreur sur la page planeur.net que voilà qui parle du 1er mai.Je comprends maintenant pourquoi ça ne marchait pas.J'ai corrigé (sans trop savoir d'ou venait l'erreur) Les mises a jours de la version 3.XX vers la version 4.XX sont a faire sans délais A+ Frederic Citer Une même passion, 3 sites : http://www.planeur.net - http://www.volavoile.net - http://www.NetCoupe.net
